Forum >About Analog Electrical Conductivity Meter (SKU: DFR0300)
userHead Account cancelled 2016-02-23 23:43:27 3658 Views1 Replies
I want to know more about how this product works. I try to understand what the program code means. here's the code I got from http://www.dfrobot.com/wiki/index.php/Analog_EC_Meter_SKU:DFR0300
// # Editor : YouYou from DFRobot
// # Date : 23.04.2014
// # E-Mail : [email protected]
// # Product name: Analog EC Meter
// # Product SKU : DFR0300
// # Version : 1.0
// # Description:
// # Sample code for testing the EC meter and get the data feedback from the Arduino Serial Monitor.
// # Connection:
// # EC meter output -> Analog pin 1
// # DS18B20 digital pin -> Digital pin 2
#include <OneWire.h>
#define StartConvert 0
#define ReadTemperature 1
const byte numReadings = 20; //the number of sample times
byte ECsensorPin = A1; //EC Meter analog output,pin on analog 1
byte DS18B20_Pin = 2; //DS18B20 signal, pin on digital 2
unsigned int AnalogSampleInterval=25,printInterval=700,tempSampleInterval=850; //analog sample interval;serial print interval;temperature sample interval
unsigned int readings[numReadings]; // the readings from the analog input
byte index = 0; // the index of the current reading
unsigned long AnalogValueTotal = 0; // the running total
unsigned int AnalogAverage = 0,averageVoltage=0; // the average
unsigned long AnalogSampleTime,printTime,tempSampleTime;
float temperature,ECcurrent;
//Temperature chip i/o
OneWire ds(DS18B20_Pin); // on digital pin 2
// initialize serial communication with computer:
Serial.begin(115200);
// initialize all the readings to 0:
for (byte thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
TempProcess(StartConvert); //let the DS18B20 start the convert
AnalogSampleTime=millis();
printTime=millis();
tempSampleTime=millis();
Every once in a while,sample the analog value and calculate the average.
if(millis()-AnalogSampleTime>=AnalogSampleInterval)
// subtract the last reading:
AnalogValueTotal = AnalogValueTotal - readings[index];
// read from the sensor:
readings[index] = analogRead(ECsensorPin);
// add the reading to the total:
AnalogValueTotal = AnalogValueTotal + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
AnalogAverage = AnalogValueTotal / numReadings;
Every once in a while,MCU read the temperature from the DS18B20 and then let the DS18B20 start the convert.
Attention:The interval between start the convert and read the temperature should be greater than 750 millisecond,or the temperature is not accurate!
if(millis()-tempSampleTime>=tempSampleInterval)
temperature = TempProcess(ReadTemperature); // read the current temperature from the DS18B20
TempProcess(StartConvert); //after the reading,start the convert for next reading
Every once in a while,print the information on the serial monitor.
if(millis()-printTime>=printInterval)
printTime=millis();
averageVoltage=AnalogAverage*(float)5000/1024;
Serial.print("Analog value:");
Serial.print(AnalogAverage); //analog average,from 0 to 1023
Serial.print(" Voltage:");
Serial.print(averageVoltage); //millivolt average,from 0mv to 4995mV
Serial.print("mV ");
Serial.print("temp:");
Serial.print(temperature); //current temperature
Serial.print("^C EC:");
float TempCoefficient=1.0+0.0185*(temperature-25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.0185*(fTP-25.0));
float CoefficientVolatge=(float)averageVoltage/TempCoefficient;
if(CoefficientVolatge<150)Serial.println("No solution!"); //25^C 1413us/cm<-->about 216mv if the voltage(compensate)<150,that is <1ms/cm,out of the range
else if(CoefficientVolatge>3300)Serial.println("Out of the range!"); //>20ms/cm,out of the range
else
if(CoefficientVolatge<=448)ECcurrent=6.84*CoefficientVolatge-64.32; //1ms/cm<EC<=3ms/cm
else if(CoefficientVolatge<=1457)ECcurrent=6.98*CoefficientVolatge-127; //3ms/cm<EC<=10ms/cm
else ECcurrent=5.3*CoefficientVolatge+2278; //10ms/cm<EC<20ms/cm
ECcurrent/=1000; //convert us/cm to ms/cm
Serial.print(ECcurrent,2); //two decimal
Serial.println("ms/cm");
ch=0,let the DS18B20 start the convert;ch=1,MCU read the current temperature from the DS18B20.
float TempProcess(bool ch)
//returns the temperature from one DS18B20 in DEG Celsius
static byte data[12];
static byte addr[8];
static float TemperatureSum;
if(!ch){
if ( !ds.search(addr)) {
Serial.println("no more sensors on chain, reset search!");
ds.reset_search();
return 0;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return 0;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized!");
return 0;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
else{
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
TemperatureSum = tempRead / 16;
return TemperatureSum;
There's a line that I still dont get:
why they have to set CoefficientVoltage<150 to print "no solution"? is there any explanation how they get that number?
And about he electrode probe, I have DJS-1E and the datasheet shows for that type it has vessel constant 1.0±0.2. I tried to validate vessel constant by measuring length and surface area of electrode. I got length 0.7cm and surface area 0.25cm^2. in wiki documentation it says vessel constant is L/A, based on that calculation I got vessel constant 2.8. am I doing something wrong here?
Thank you.
2016-02-26 22:43:15 Hi Ajis.aprl,
Welcome! :)
The coefficients in the code are all by many tests by the research guys. Sorry but I don't know your another question.
userHeadPic Leff
