sen0161 software calibration vs Adjustment Potentiometer
To adjust pH 7 we do it with the offset directly in the code, but is there a way to do the same for pH 4 and pH 10 instead of using the potentiometer? If not, is it possible to replace the potentiometer with some hardware parts to do it programmatically?
Thanks,
Kevin
Thanks,
Kevin
2016-04-01 12:25:32 Thanks for the information. I have passed your idea to the relevant department as a suggestion, but now, it doesn't support so I think. Leff
