Forum >response time problem on sim700c mqtt command "AT+SMCONN"
need help on mqtt connection with sim7000c updated firmwire
when i connect it to mqtt server with command "AT+SMCONN" it get connect in few seconds.But if i restart gsm and try to connect it again it wait for nearly 5 minutes to response.
And also response is so many time error.
Can any one please tell the solution for this?
2019-09-27 07:51:50 Alhamdulillah it was successful, when my server username and password were disabled, SIM7000C successfully connected.
Thank you for Ms. Nana
muhammadarsyil21
muhammadarsyil21
2019-09-24 21:10:14 Here goes the AT Command listing:
OK
AT+SMCONF="CLIENTID","212"
OK
AT+SMCONF="URL",147.xxx.xxx.50:1883
OK
AT+SMCONF="KEEPTIME",60
OK
AT+SMCONF="CLEANSS",1
OK
AT+SMCONF="USERNAME","sensor"
OK
AT+SMCONF="PASSWORD",hxxxxxxxxxxxxxxQ
OK
AT+SMCONF="QOS",0
OK
AT+SMCONF="TOPIC","sensors"
OK
AT+SMCONF?
+SMCONF
CLIENTID: "212"
URL: 147.xxx.xxx.50:1883
KEEPTIME: 60
USERNAME: "sensor"
PASSWORD: "hxxxxxxxxxxxxxxQ"
CLEANSS: 1
QOS: 0
TOPIC: "sensors"
MESSAGE: ""
RETAIN: 0
OK
AT+SMCONN
ERROR
muhammadarsyil21
OK
OK
OK
OK
OK
OK
OK
AT+SMCONF="QOS",0
OK
OK
AT+SMCONF?
+SMCONF
CLIENTID: "212"
KEEPTIME: 60
USERNAME: "sensor"
CLEANSS: 1
QOS: 0
TOPIC: "sensors"
MESSAGE: ""
RETAIN: 0
OK
AT+SMCONN
ERROR
OK
OK
OK
OK
OK
OK
OK
AT+SMCONF="QOS",0
OK
OK
AT+SMCONF?
+SMCONF
CLIENTID: "212"
KEEPTIME: 60
USERNAME: "sensor"
CLEANSS: 1
QOS: 0
TOPIC: "sensors"
MESSAGE: ""
RETAIN: 0
OK
AT+SMCONN
ERROR
muhammadarsyil21
OK
OK
OK
OK
OK
OK
OK
AT+SMCONF="QOS",0
OK
OK
AT+SMCONF?
+SMCONF
CLIENTID: "212"
KEEPTIME: 60
USERNAME: "sensor"
CLEANSS: 1
QOS: 0
TOPIC: "sensors"
MESSAGE: ""
RETAIN: 0
OK
AT+SMCONN
ERROR
2019-09-24 17:47:33 I have adjusted the parameters according to the server, but still cannot connect to the server, the information here I am using the VERNEMQ server (for the MQTT server).
When I tried the SIM7000C module to connect to the local or other server that I made myself it was successful
muhammadarsyil21
muhammadarsyil21
2019-09-20 17:54:59 Do all parameters in AT + SMCONF have to be set or only some of them like (URL, USERNAME, PASSWORD)?
muhammadarsyil21
muhammadarsyil21
2019-09-19 21:29:04 I want to ask, I also encountered problems when running the AT-SMCONN command for the 7000C SIM module.
Can anyone give me a solution?
Thank you
muhammadarsyil21
Thank you
Thank you
muhammadarsyil21
Thank you
2019-08-29 23:50:35 need help on mqtt connection with sim7000c updated firmwire
sarojflame
