CONFLICTO ENTRE DFR0300 Y DFRDUINO M0
no puedo cargar el programa ejemplo de DFR0300 en el DFRduino M0 ya que me da conflicto con la EEPROM
habría forma de solucionarlo?
2019-09-12 18:52:21 It seems that Arduino have not provided the EEPROM library of the M0 controller, so the library you used now is not compatiable with your product. You could use some classic controllers like Arduino UNO, Leonardo to avoid this problem. Youyou
