WIRELESS PROGRAMMING MODULE (WPM) NOT WORKING
Have you set the WPM to the right setting which is compatible with the board you are programming.
BTW, make sure the address of your WPM is the same. You can adjust the address via the WPM Tools.
The address of WPM looks like " 192.168.1.1.1"
The frequency of two WPM should be exactly the same.
And please explain a little bit to identify your program.
