Forum >Problem with Arduino Romeo V2 - flashing led
userHead anonymous 2019-09-13 09:33:33 2079 Views1 Replies
Hi, I've an Arduino Romeo V2, when I connect the battery (nihm 6V 1600 mAh) le main led (red) of the board flashes... If I connect the USB cable to the USB port, the led is stable on red light and motors works with the external power. I've tried 2 batteries, same problem.
Can you help me?
Thanks!
2019-09-16 18:23:08 Hey,
Can you test that the battery is outputting a stable 6V. The Roemo V2 has a voltage input range between 6v-23V for external power (batteries in your case). Since you are right at the minimum level I assume the issue is related to not supplying enough power from your batteries.
userHeadPic robert
