Forum >LattePanda Forum
LattePandaGeneral
LattePanda Forum
userHead tcmartin999 2019-09-15 07:38:49 11684 Views18 Replies
Hi Guys
has anyone else had problems accessing the LattePanda forum "https://www.lattepanda.com/forum"? I registered on 2nd September and they still haven't activated the account!
Is there anyone one here who can give the admins a kick, please?
2020-05-30 11:26:48 I can't log into that forum. Even after changing my password I can't get past that anti robot software. userHeadPic lasakro
2020-05-29 22:35:32 I'm reloading Win 10 Pro on Delta, installs fine on the built-in 32GB but how do I direct it to install on 256GB NVMe M.2 in installed?
I'm following the below instruction which doesn't have it as an option:
http://docs.lattepanda.com/content/1st_edition/os/
userHeadPic lasakro
userHeadPic lasakro
2020-02-05 21:58:37 Hi we recommend u use LattePanda Alpha Models. (for better performance)
there are several video tests on Youtube. you can check for reference. thanks.
https://youtu.be/LMsrVbjOJU8
userHeadPic Queenie.Le
2020-01-21 03:42:54 Thinking of buying this as a gift. What is the best LattePanda model+GPU combo for PS4-level gaming? userHeadPic jackoscar4856
2019-09-26 11:22:51 Hi, folks!
If you recommend me a DVB S2 module to connect with LattePanda Alpha?
Thank you in advance,
Roman
userHeadPic anonymous
Roman
