Forum >infrared with Motor:bit board
RoboticsGeneral
userHead jobaret 2019-10-03 13:52:41 3981 Views2 Replies
I want to use infrared receptor (on pin 16) with Motor:bit board and Mind+.
If I use Maqueen extension on Mind+ with Motor:bit board, it's OK (with block "when (P16) received infrared signal") but I can't use motors because it isn't Motorbit extension.
If I use Motorbit extension on Mind+ with Motor:bit board (to use motors), I can't use infrared receptor.
So, can you make a "when (P16) received infrared signal" block for Motor:bit board ?
Thank you.
2019-10-09 23:38:21 Yes ! With Communication ectension (IR receiver module) and Motorbit extension it's OK.
Thank you.
userHeadPic jobaret
