Forum >Maqueen v4. Programming course with Maqueen
userHead mi_semion 2019-11-10 12:52:29 11188 Views5 Replies
I received maqueen v4.
1. About packaging and hardware
Good progress:
-now a small booklet is included.
- mounting M3 holes are marked - it's desirable to do so in online instruction as well
- pins for 2 servo provided - it would be better to mark which ports are used there as well (is it p17,18?)
2. Map of Patrol line
- iI received 2-rings map while in online documentation it's oval track (I do not complain, just mark a discrepancy)
- looks like the distance between sensors and size of line are the same (15mm?). I had an observation a few years ago, with my own model, that more optimal is having sensors a bit (2-3mm) wider than size of line
3. I've published a programming course with maqueen in Russian, for age 10-13, 12 academic hours (45min). and soon to start on continuation (more exactly. it's rather material for a teacher)
Should Dfrobot have an interest in English version of the course, we may discuss it.
Mikhail Semionenkov, educator. PhD
2022-01-26 22:01:55 Very informative article. Really looking forward to read more. Thank you for the post.
https://tokeandsmokeshop.com
userHeadPic lokiwong3
2021-07-12 22:00:32 This is interesting buy distillate online and buy weed online userHeadPic back18021
2021-06-04 09:49:02 nice course what about Surfshark VPN review 2021! userHeadPic muneebn660
2019-11-11 05:26:05 Also. thank you for new packaging which allow not to use scissors: it's a big plus.
One more thing: an option "servos+stuff to attach them" is highly desirable
userHeadPic mi_semion
