Forum >Galvanic Dissolved Oxygen Sensor circuit board
userHead MOJKARIM357 2019-11-11 09:20:36 2941 Views5 Replies
Would you please help me for find Galvanic Dissolved Oxygen Sensor circuit board ?
2019-11-23 00:22:04 Hello, the ph sensor circuit is different from the dissolved oxygen sensor circuit.
By the way, do you want to DIY the circuit?
userHeadPic Youyou
2019-11-12 21:10:23 is circuit board of ph meter the same as circuit board dissolved oxygen sensor? can i use from circuit board of ph meter for circuit board of dissolved oxygen sensor ? userHeadPic MOJKARIM357
2019-11-12 08:12:01 Thanks but in this link there is any circuit board that has TP5551 op-amp . unfortunately i can not find this op-amp.
1)i can not find TP5551 in my place then can i replacement by OP177GP or AD623AN or OP77GP or AD8572ARZ ? if i can do it then which of them is the best ?
2)If i can replacement TP5551 by another op-amp , is need change in circuit board or only i can replace without any change ?
3) if these op-amps ( OP177GP or AD623AN or OP77GP or AD8572ARZ ) are not the best choices please tell me your offer.
