New W5200
I also get link down but the cable is good
Link Status
This sketch prints the ethernet link status. When the
ethernet cable is connected the link status should go to "ON".
NOTE: Only WizNet W5200 and W5500 are capable of reporting
the link status. W5100 will report "Unknown".
Hardware:
- Ethernet shield or equivalent board/shield with WizNet 5200/5500
Written by Cristian Maglie
This example is public domain.
#include <SPI.h>
#include <Ethernet.h>
// You can use Ethernet.init(pin) to configure the CS pin
Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet
Serial.begin(9600);
auto link = Ethernet.linkStatus();
Serial.print("Link status: ");
switch (link) {
case Unknown:
Serial.println("Unknown");
break;
case LinkON:
Serial.println("ON");
break;
case LinkOFF:
Serial.println("OFF");
break;
delay(1000);
Link Status
Hardware:
#include <SPI.h>
Serial.begin(9600);
switch (link) {
case Unknown:
break;
case LinkON:
break;
case LinkOFF:
break;
delay(1000);
