TDS METER
Hi!
Reviewing the code you propose for tds measurements seems strange to me the way it compensates and measures:
You propose this:
1) It is compensating the temperature from a voltage value. WHY?
2) Could you explain a little better why you are using that voltage conversion to tds?
Thank you very much!
Best regards.
You propose this:
But:float compensationVolatge = average Voltage / compensation Coefficient; // temperature compensation
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge - 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5; // convert the voltage value to the tds
Best regards.
