Forum >32x16 RGB LED Matrix not lighting up correctly
userHead Account cancelled 2019-12-27 05:48:38 1815 Views3 Replies
I purchased this board: SKU_DFR0471
After connecting the pinouts as follows
32x16 Matrix Board UNO
1 2
2 3
3 4
4 GND
5 5
6 6
7 7
8 GND
9 A0
10 A1
11 A2
12 GND
13 8
14 A3
15 9
16 GND
When I run Sample Code 1 and Sample Code 2, only the bottom half rows light up (see attached), neither sample code works as expected.
Please help!
icon IMG_8079.jpg Download(0)
icon IMG_8081.jpg Download(0)
icon IMG_8082.jpg Download(0)
icon IMG_8083.jpg Download(0)
icon IMG_8084.jpg Download(0)
icon IMG_8085.jpg Download(0)
icon IMG_8086.jpg Download(0)
2023-02-21 17:22:52
I have checked the wiki of this module, did you connect power supply here? You didn't mentioned in your connection.
Also, It needs an external power supply, did you added on your arduino board?
Hope it can help.
userHeadPic NeloKin
2023-01-28 01:36:54
1800lighting coupons
userHeadPic charlotte.amylia
2023-01-28 01:36:04
If you Really want to install external lightning in you pc and you wanna decorate it more you can check 1800lighting In which you will get an amazing facilities More don't forget to use 1800lighting coupons.
