Forum >HuskyLens/Devastator basic code
HUSKYLENSGeneral
userHead Account cancelled 2019-12-30 09:17:50 4476 Views0 Replies
Hello Fellow Backers,
I have managed to compile and test tethered basic Robot Devastator code, I still haven't got the untethered Bluetooth working yet, although the RomeoBLE RX does flash upon each command. I have the HuskyLens installed on a MG90 servo attached to port D3, but have not coded in, but display illuminates. As a start, Here is the code: and a link to DEMO video. ( https://youtu.be/c2Jpe7898S8 )
# Editor : Phoebe
# Date : 2014.11.6
# Ver : 0.1
# Product: Devastator Tank Mobile Platform
# SKU : RBO0112
# Description:
# Connect the D4,D5,D6,D7,GND to UNO digital 4,5,6,7,GND
# Revised by James Martel
# Revision Date: 2019.12.29w
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
void stop(void) //Stop
//digitalWrite(E1,0);
digitalWrite(E1,LOW);
//digitalWrite(E2,0);
digitalWrite(E2,LOW);
void advance(char a,char b) //Move forward
analogWrite (E1,a); //PWM Speed Control
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
void back_off (char a,char b) //Move backward
analogWrite (E1,a);
digitalWrite(M1,LOW);
analogWrite (E2,b);
digitalWrite(M2,LOW);
void turn_L (char a,char b) //Turn Left
analogWrite (E1,a);
analogWrite (E2,b);
void turn_R (char a,char b) //Turn Right
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
Serial.begin(19200); //Set Baud Rate
Serial.println("Run keyboard control");
//digitalWrite(E1,LOW);
//digitalWrite(E2,LOW);
void loop(void)
if(Serial.available()){
char val = Serial.read();
if(val != -1)
switch(val)
case 'w'://Move Forward
advance (255,255); //move forward in max speed
break;
case 's'://Move Backward
back_off (255,255); //move back in max speed
break;
case 'a'://Turn Left
turn_L (200,150);
break;
case 'd'://Turn Right
turn_R (150,200);
break;
case 'z':
Serial.println("Hello");
break;
case 'x':
stop();
break;
else stop();
