Forum >Latte panda shuts off
LattePandaGeneral
userHead 202885harold 2016-06-01 15:11:35 3585 Views2 Replies
I start up my latte panda and it opens the the login screen I log in then it shuts down I have a micro usb cable hooked up to a wall plug that outputs 2.1 amps 5v
2017-08-14 10:33:32 2.1 amps is not an adequate supply. You need at least 3.0 amps. Even a 2.4 amp supply is marginal. userHeadPic raymostrom
2016-06-02 00:39:57 Hi
It looks like the LP doesn't have enough current. Try a high quality USB cable.
userHeadPic Wendy.Hu
