Forum >Latte panda does not work Faulty unit?
when I try to plug in my latte panda I see a blue flashing light but no red light and when I press the power button nothing happens
2017-10-14 16:02:58 I was using my LattePanda and suddenly turned off, if I connect the power cable, blue led blinks and the screen still off.
What happened???
I hardly use it
freezer27
What happened???
I hardly use it
2017-03-02 01:23:41 Has this worked for anybody else just got it, was using the samsung cable can anybody tell me the name of a good cable that is available in KSA
hisaananjum1
2016-06-03 21:23:05 I don't thing it's a power problem because I have 5v 2.4 amps and a cable I know works properly I've tried contacting technical support a day ago and they have not responded
202885harold
2016-06-03 19:11:43 I'm having the same issue. I can't boot the device for the first time. it just blinks a blue light
Anybody have any advice? Is this a power issue, or do I have a faulty unit?
bretyancy
