Forum >Latte Panda not working (Not A Power Problem)
whenever I plug in my latte panda only the blue light turns on and the red one does not I use an 5v 2.4 amp power source and have tried reimaging my latte panda it still does not work btw when I plug in a ethernet cable into my LP the lights light up on the port
2016-12-24 03:12:45 a possible solution might be after connecting to the power supply.. once the red light goes off, wait 1 second and you may have forgotten to press the power button ( The button on the side beside the reset button) for a second. Hopefully, windows should start up.
maestro-adversity
2016-12-08 10:05:50 Yeah i am encountering the same problem... blue light blink. Red light on for a while... when i press on button again, blue light just blinked a few times... before nothing hppn.. help pls
maestro-adversity
2016-06-09 05:13:52 The USB power adapter can have as many amps as you like, BUT not all USB cables can cope with it, I personally only use 250mm length USB cables on both of my 64gb Pandas.
itscervo
2016-06-09 01:10:21 IT is NOT a power issue and I have tried getting help from the website you gave me and no one knows how to fix it and I have tried sending emails for the past week to the latte panda team and the furthest I got was them telling me to use a different power source so I then proceeded to prove that it was not a power source issue (again) and now I have not received an email from them for the past 2 days
202885harold
2016-06-08 23:33:05 sounds like a powr source issue, but also possible that the LP got defective, you can go to http://www.lattepanda.com/forum/ for official help.
Leff
