Forum >Bluno Demo Basics
Bluno General Arduino
Bluno Demo Basics
userHead KamalakkannanGv 2016-06-15 21:43:18 4711 Views5 Replies
Hi there
The demo in github is different from actual apk
https://github.com/DFRobot/BlunoBasicDemo
can please update the new code for android
with this code the generated app cannot connect with bluno
Please verfiy the bluno library code if possible
thankyou
2016-06-17 00:16:16 Hi KamalakkannanGv,
We haven't test the Bluno Demo Basics on Android 6.0 yet.
So it may not be work on it. Would you mind test it on Android 5.* or Android 4.*.
Or try to set the SDKTargetVersion in Android studio to 19, to run the code in compatible mode.
userHeadPic Angelo.Qiao
2016-06-16 19:21:58 Hi KamalakkannanGv,
I've told him, but not sure if he has fixed that?
Can you Pull request from Github and commit there, that would be help you to get the notice from him directly. :)
userHeadPic Leff
2016-06-16 14:49:33 Hi there I tried using the code again nothing works!
Did your technical team updated the code ?
If so can you provide me the link of working android code?
thankyou
userHeadPic KamalakkannanGv
2016-06-16 01:28:33 It sounds like that our engineer forget to save after last modification. I will pass it to our team, you will get the available source code there. userHeadPic Leff
2016-06-16 01:12:57 I didn't modified anything exact same code from github,this how it works
https://youtu.be/2rFK0ypUras
scanning and connecting and again to scan
second time when i do nothing happens.
So please provide me a a working demo ,that you use to test.
