Forum >Display extension cable
I would like to use the LattePanda display with a longer cable. Is there a longer cable available or an extension of the cable available?
2016-08-23 08:42:44 I was thinking about the exact same thing. Haven't bought the LattePanda yet.
Found most of the stuff you would need to do that on "aliexpress" by searching for "FFC cable/FFC connector" and "FPC cable/FPC connector". Still need to figure out what goes for what, but you can use what you can get there for about $20+ to get an extension going. Can also add something like a springy telephone cord in the middle. Other wise I might go check in some old keyboards and mice if I find the same connector and work it out from there. Remember you also might have the touch screen cable to extend, so if you don't have one now, make sure you plan ahead for if you get one later.
ReinhardB14
