Forum >power boost
LattePandaGeneral
power boost
userHead 202885harold 2016-07-01 02:29:35 2606 Views1 Replies
hello I want to have a battery for my lattepanda and I want to use lithum ion battries and the only ones I could find were only 1 amp and I was woundering if anyone has found one that has 2 amps and works with the lattepanda
2016-07-01 22:52:56 Hi
In DF ,there is a 7.4V Lipo 2200mAh Battery with 1C continuous discharge rate (5C MAX)
https://www.dfrobot.com/index.php?route= ... 3YO3-bmXr0
It can work with LattePanda BUT not directly you need step-down to 5V
userHeadPic Wendy.Hu
