Forum >Bluno M3 - bootloader lost
Does anyone know where to find the CC_Debugger pin definition for connecting a CC_Debugger to a Bluno M3 V2.1.
Thanks a lot
Tom
Thanks a lot
Tom
2016-07-20 22:05:47 Very sorry Tom for my late reply.
To your question, I did met the same problem before, and there are two possible reasons:
If you happen to have another card with CC2540, that would help much to distinguish which should be the reason.
Leff
- The wiring is wrong. Could I get a picture for me to check? (I did made a lot of mistake on that)
- CC2540 got burned.
2016-07-14 20:20:35 Thanks Leff,
I received my CC_DEBUGGER from TI. I wired according to the diagram and could not get the green light to go on. I wonder if the board had a different problem.
Any recommendation ? ( I have also purchased a new board so my work continues but I am curious if I can try anything else)
Tom
tomch
Tom
