Forum >Tiny Wireless Charger Receiver (Qi Compatible) (DFR0380)
I bought two modules.
I tried to bring them to charge Nokia DT-900 - does not work. No connection charge.
This module does not work?
On what they charge to use?
2016-11-24 00:13:30 Hi aslan87,
You mean you used this receiver with your transmitter, right? If yes, its possible to be the distance beyond the range, maybe you can put the receiver to the transmitter coil directly.
And sorry, the old link is already no longer exited, since we found the transmitter and the receiver is not very match, we dont sell the kit now.
Wendy.Hu
2016-11-22 16:01:45 Hello! I also tried with standard qi transmitter, and it doesn't work!
The link to the kit is broken.. Can you post again, so we can order and try with that?
Thanks!
taslan87
Thanks!
2016-07-08 23:11:35 Hi
This is a receiver part. there is another kit which has been include this part, please check:
https://www.dfrobot.com/index.php?route= ... 39SCzWld65
Wendy.Hu
