Forum >Problem with 7" Touch Display for LattePanda
Hi Guys,
I report the video of my big problem with 7-inch 1024x600 IPS Display+Touch for LattePanda. In condition of white image the Display reflash continuously and become unusable. I have used different power adapter up to 5 amps but the result is the same.
I don't know if the dsplay have an hardware problem or the problem is the connector on lattepanda.
Somebody could help me?
Video information
https://youtu.be/84-i6zNUKV8
Video information
2016-08-28 21:49:55 Hi, I know it's a bit late, I just got my panda now. I've had the same problem with my display but I realized that there is a small bracket on the display port on the board that you must pressed down in order for the display plug to be locked down. After that it work correctly.
WesselCronje
2016-07-13 00:38:22 Hi acarrizzo1,
Its very possible to be caused due to a short-circuit , system restart, then the IPS screen interface damaged when you are connecting the display.
Maybe you need to send it back for repair. You could go to PRODUCTS RETURNS page to request an RMA number and wait for our store to deal with the request.
Wendy.Hu
2016-07-12 02:27:34 Come on guys help me !!!
I have also try to reduce the brightness without results.
How I can test a possible problem of power....I not have any problem on HDMI port.
How I can try to solve the probelm?
help help help
acarrizzo1
help help help
