Forum >Romeo BLE and Goble App
Bluno General Arduino
userHead Account cancelled 2016-07-16 08:15:36 2397 Views1 Replies
I purchase the Devastator with the Romeo BLE, (SKU DFR0305) . I installed the Goble app in my Ipad connect the Romeo to my MAC with the USB cable and download the test app. Open the Bluetooth in the IPAD and connect to Bluno. Search with the Goble app and found the Romeo, run the test everything work perfect. Unplug the USB cable to break the link, connect again the USB cable and download the Application, when to the IPAD and connect to Bluno, no problem here, but when I search for the Romeo
with Goble app, never found the Romeo again, in the Romeo the link lead is ON (Green) indicating a link, I try different IPAD, try IPHONE 6, reload the test program, same thing the Goble app can not found any device.
What could be the problem? it works perfect the first time.
Found the problem, this was in a couple of libraries; #include "WProgram.h" I comment this line in the libraries, and is working, but there is another error, the robot runs in circle when not touching the joystick
2016-07-18 23:08:28 Hi Cure Rafael,
Sorry, can I confirm what kind of settings have you had? Did you set the Romeo as a CENTRAL device? If you did, you wouldnt find the Romeo.
And I am not very clear the library you said, which is supplied by us?
Looking forward to your reply.
userHeadPic Wendy.Hu
