Forum >Problem with Veyron 2x25A Brush DC Motor Driver SKU: DRI002
RoboticsGeneral
userHead Skaner3Dbody 2016-07-23 04:35:04 4035 Views3 Replies
I have a problem with the modification of settings. I can't change options like max velocity and mode loop. Is it possible to change this options in the Vayeron driver?
Thanks in advance.
MC
2016-08-11 01:07:21 Hi
The command is "1,SVS,1,100", "100" not " 1,SVM,1,1000",you did the right thing?
userHeadPic Wendy.Hu
2016-08-10 03:08:34 Thanks for help. Unfortunately, your solution didn't solve my problem. I want to change value of Maximum velocity and velocity mode. When I used AutoPID, a DC motors got a different parameters of max velocity. In this case it's hard to precisely control a motors. I send you a photo of configuration where I checked options which I want to change.
I tried to use 1,SVM,1,1000, but it didn't work.
https://drive.google.com/open?id=0B7hEP ... G1KdDY3Tjg
userHeadPic Skaner3Dbody
2016-07-25 23:43:25 Hi Skaner3Dbody,
Sorry, I didn't play this product before, i will reply you after I finish testing as soon as possibe.
