Forum >gps gsm gprs shield - help
userHead NataliaSiska 2016-07-29 09:46:36 3976 Views3 Replies
i have a problem with this shield
i use this sketch :
#include <SoftwareSerial.h>
int8_t answer;
int onModulePin = 3;
int baud_rate = 9600;
int pin_gsm = 3;
int pin_gps = 4;
int pin_power = 5;
boolean debug = true;
boolean ready_to_go = false;
char data[100];
int data_size;
char aux_str[30];
char aux;
int x = 0;
char N_S,W_E;
char url[] = "demo.alphamedia.web.id/arduino/gps";
char frame[200];
char latitude[15];
char longitude[15];
char altitude[6];
char date[16];
char time[7];
char satellites[3];
char speedOTG[10];
char course[10];
char imei;
char cimei;
// setting no telp untuk menerima sms dan telepon
char phone_number[]="+6289689321978";
char aux_string[30];
int ledpin = 13;
int ledgps = 10;
int ledground = 11;
int ledengine = 8;
char inchar;
uint8_t istrack = 0;
void setup(){
Serial.begin(baud_rate);
delay(5000);
if(debug)
Serial.println(F("\n****************************"));
Serial.println(F("STARTING SYSTEM Read AT stream"));
Serial.println(F("******************************"));
pinMode(pin_gsm,OUTPUT); // Set the pins
pinMode(pin_gps,OUTPUT);
pinMode(pin_power,OUTPUT);
pinMode(ledengine,OUTPUT);
pinMode(ledpin,OUTPUT);
pinMode(ledgps,OUTPUT);
pinMode(ledground,OUTPUT);
digitalWrite(ledground,LOW);
digitalWrite(ledpin,HIGH);
powerUpSim908:
if(powerUpSim908())
delay(1000);
digitalWrite(ledgps,HIGH);
gps_on();
digitalWrite(ledgps,LOW);
gsm_enable();
ready_to_go = true;
sendATcommand("AT", "OK", 2000);
//sendATcommand("AT+CPIN=?", "OK", 2000);
sendATcommand("AT+CPIN?", "OK", 2000);
sendATcommand("AT+CSQ", "OK", 2000);
while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 1000)) == 0 || sendATcommand("AT+CREG?", "+CREG: 0,5", 1000));
sendATcommand("AT+CLIP=1", "OK", 1000);
while ( start_GPS() == 0);
delay(2000);
digitalWrite(ledpin,LOW);
sendATcommand("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"APN\",\"internet\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"USER\",\"\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"PWD\",\"\"", "OK", 2000);
Serial.println("AT+SAPBR=1,1");
delay(10000);
Serial.println("AT+HTTPINIT");
delay(2000);
Serial.println("AT+HTTPPARA=\"CID\",1");
delay(2000);
while (sendATcommand("AT+SAPBR=4,1", "OK", 20000) == 0)
delay(5000);
if(debug)
Serial.println("AT+CMGD=1,4");
Serial.println("Hapus pesan masuk....");
Serial.println(F("READY TO GO\n"));
Serial.println(F("****************************\n"));
else
if(debug)
Serial.println(F("\nNOT READY TO GO.\nCheck the battery level.\n"));
void loop(){
if(ready_to_go)
if(Serial.available()>0)
// untuk membaca pesan masuk di uriutan pertama
inchar=Serial.read();
if(inchar=='T')
delay(10);
if (inchar=='I')
delay(10);
// read message at position 1
Serial.println("AT+CMGR=1");
delay(10);
// start and stop engine
else if (inchar=='S')
// perintah sms "SE" untuk menghidupkan mesin
delay(10);
if (inchar=='E')
Serial.println("(SE) Hidupkan Mesin ...");
delay(10);
digitalWrite(ledengine,HIGH);
delay(50);
Serial.println("AT+CMGD=1,4"); // hapus seluruh pesan masuk (sms inbox)
delay(100);
// perintah sms "ST" untuk mematikan mesin
if (inchar=='T')
Serial.println("(ST) Matikan Mesin ...");
delay(10);
digitalWrite(ledengine,LOW);
delay(50);
delay(100);
// gps
else if (inchar=='G')
// perintah sms "GN" untuk memulai mode pemindaian GPS dan mengirimkan titik lokasi ke server
delay(10);
if (inchar=='N')
Serial.println("(GN) Kirim koordinat lokasi ...");
delay(10);
delay(50);
get_GPS();
send_HTTP(); // kirim titik lokasi ke server
delay(2000);
delay(500);
// perintah sms "GM" untuk mengirimkan titik lokasi ke no dfrobot
if (inchar=='M')
Serial.println("(GS) Kirim koordinat lokasi vis SMS...");
delay(10);
get_GPS();
boolean iskirim = false;
if(!iskirim) {
sendSMS();
iskirim = true;
delay(1000);
delay(100);
// perintah sms "GS" untuk menghentikan tracking GPS
if (inchar=='S')
Serial.println("(GS) Stop GPS Tracking ...");
delay(10);
delay(50);
istrack = 0;
//stop_gps();
gpsTracking(0);
delay(5000);
delay(100);
if (inchar=='T')
Serial.println("(GT) Start GPS Tracking ...");
delay(10);
get_GPS();
delay(100);
gpsTracking(istrack);
if (inchar=='1')
Serial.println("(G1) set GPS Tracking ON ...");
istrack=1;
delay(100);
if (inchar=='0')
Serial.println("(G0) set GPS Tracking OFF ...");
istrack=0;
delay(100);
// melakukan panggilan ke no dfrobot
else if (inchar=='P')
// perintah sms "PC" untuk menghubungi no
delay(10);
if (inchar=='C')
Serial.println("(PC) Lakukan panggilan telepon...");
delay(10);
delay(50);
Serial.println("AT");
delay(2000);
//Make a phone call
Serial.println("ATD+6289689321978;");
while(1);
delay(100);
delay(100);
// perintah "PS" untuk menutup telepon
if (inchar=='S')
Serial.println("(PS) Tutup panggilan telepon...");
delay(10);
delay(50);
//Make a phone call
Serial.println("ATH");
delay(100);
delay(100);
} //end ready_togo
} // end loop
void stop_gps(){
uint8_t answer=0;
sendATcommand("AT+CGPSPWR=0", "OK", 2000);
gps_stop();
answer = sendATcommand("AT", "OK", 2000);
if (answer == 0)
// waits for an answer from the module
while(answer == 0){
int8_t start_GPS(){
unsigned long previous;
previous = millis();
// starts the GPS
//sendATcommand("AT", "OK", 2000);
sendATcommand("AT+CGPSPWR=1", "OK", 2000);
sendATcommand("AT+CGPSRST=0", "OK", 2000);
// waits for fix GPS
while(( (sendATcommand("AT+CGPSSTATUS?", "2D Fix", 5000) ||
sendATcommand("AT+CGPSSTATUS?", "3D Fix", 5000)) == 0 ) &&
((millis() - previous) < 90000));
if ((millis() - previous) < 90000)
return 1;
else
return 0;
int8_t get_GPS(){
int8_t counter, answer;
long previous;
// First get the NMEA string
// Clean the input buffer
while( Serial.available() > 0) Serial.read();
// request Basic string
sendATcommand("AT+CGPSINF=0", "AT+CGPSINF=0\r\n\r\n", 2000);
counter = 0;
answer = 0;
// Initialize the string
memset(frame, '\0', 100);
// this loop waits for the NMEA string
do{
if(Serial.available() != 0){
frame[counter] = Serial.read();
counter++;
// check if the desired answer is in the response of the module
if (strstr(frame, "OK") != NULL)
answer = 1;
// Waits for the asnwer with time out
while((answer == 0) && ((millis() - previous) < 2000));
frame[counter-3] = '\0';
// Parses the string
strtok(frame, ",");
strcpy(longitude,strtok(NULL, ",")); // Gets longitude
strcpy(latitude,strtok(NULL, ",")); // Gets latitude
strcpy(altitude,strtok(NULL, ".")); // Gets altitude
strtok(NULL, ",");
strcpy(date,strtok(NULL, ".")); // Gets date
strtok(NULL, ",");
strtok(NULL, ",");
strcpy(satellites,strtok(NULL, ",")); // Gets satellites
strcpy(speedOTG,strtok(NULL, ",")); // Gets speed over ground. Unit is knots.
strcpy(course,strtok(NULL, "\r")); // Gets course
convert2Degrees(latitude);
convert2Degrees(longitude);
return answer;
/* convert2Degrees ( input ) - performs the conversion from input
* parameters in DD°MM.mmm’ notation to DD.dddddd° notation.
* Sign '+' is set for positive latitudes/longitudes (North, East)
* Sign '-' is set for negative latitudes/longitudes (South, West)
int8_t convert2Degrees(char* input){
float deg;
float minutes;
boolean neg = false;
//auxiliar variable
char aux[10];
if (input[0] == '-')
neg = true;
strcpy(aux, strtok(input+1, "."));
else
strcpy(aux, strtok(input, "."));
// convert string to integer and add it to final float variable
deg = atof(aux);
strcpy(aux, strtok(NULL, '\0'));
minutes=atof(aux);
minutes/=1000000;
if (deg < 100)
minutes += deg;
deg = 0;
else
minutes += int(deg) % 100;
deg = int(deg) / 100;
// add minutes to degrees
deg=deg+minutes/60;
if (neg == true)
deg*=-1.0;
neg = false;
if( deg < 0 ){
neg = true;
deg*=-1;
float numeroFloat=deg;
int parteEntera[10];
int cifra;
long numero=(long)numeroFloat;
int size=0;
while(1){
size=size+1;
cifra=numero%10;
numero=numero/10;
parteEntera[size-1]=cifra;
if (numero==0){
break;
int indice=0;
if( neg ){
indice++;
input[0]='-';
for (int i=size-1; i >= 0; i--)
input[indice]=parteEntera[i]+'0';
indice++;
input[indice]='.';
indice++;
numeroFloat=(numeroFloat-(int)numeroFloat);
for (int i=1; i<=6 ; i++)
numeroFloat=numeroFloat*10;
cifra= (long)numeroFloat;
numeroFloat=numeroFloat-cifra;
input[indice]=char(cifra)+48;
indice++;
input[indice]='\0';
void send_HTTP(){
uint8_t answer=0;
// Initializes HTTP service
sendATcommand("AT+CGATT=1", "OK", 2000);
sendATcommand("AT+SAPBR=2,1", "+SAPBR:", 2000);
//answer = sendATcommand("AT+HTTPINIT", "OK", 10000);
sendATcommand("AT+HTTPINIT", "OK", 5000);
// Sets CID parameter
sendATcommand("AT+HTTPPARA=\"CID\",1", "OK", 2000);
Serial.print("AT+HTTPPARA=\"URL\",\"http://demo.alphamedia.web.id/arduino/gps/trak.php?visor=false&latitude=");
Serial.print(latitude);
Serial.print("&longitude=");
Serial.print(longitude);
Serial.print("&altitude=");
Serial.print(altitude);
Serial.print("&time=");
Serial.print(date);
Serial.print("&satellites=");
Serial.print(satellites);
Serial.print("&speedOTG=");
Serial.print(speedOTG);
Serial.print("&course=");
Serial.print(course);
Serial.println("\"");
delay(2000);
Serial.println("AT+HTTPACTION=0"); //now GET action
delay(2000);
Serial.println(F("Done!"));
sendATcommand("AT+HTTPTERM", "OK", 5000);
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout){
uint8_t x=0, answer=0;
char response[100];
memset(response, '\0', 100);
delay(100);
// Send the AT command
Serial.println(ATcommand);
x = 0;
// this loop waits for the answer
do{
response[x] = Serial.read();
x++;
if (strstr(response, expected_answer1) != NULL)
answer = 1;
while((answer == 0) && ((millis() - previous) < timeout));
return answer;
boolean sendSMS(){
delay(3000);
Serial.println("Konek ke jaringan...");
while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
Serial.print("Setting mode SMS...");
// sets the SMS mode to text
sendATcommand("AT+CMGF=1", "OK", 1000);
Serial.println("Kirim SMS");
sprintf(aux_string,"AT+CMGS=\"%s\"", phone_number);
// send the SMS number
answer = sendATcommand(aux_string, ">", 2000);
if (answer == 1)
Serial.print("Posisi sekarang ada di: ");
Serial.print("Latitude: ");
int i = 0;
while(latitude[i]!=0){
Serial.print(latitude[i]);
i++;
Serial.print(" / Longitude: ");
i = 0;
while(longitude[i]!=0){
Serial.print(longitude[i]);
i++;
Serial.write(0x1A);
answer = sendATcommand("", "OK", 20000);
if (answer == 1)
delay(500);
Serial.print("sms terkirim ");
else
Serial.print("Error ");
else
Serial.print("error ");
Serial.println(answer, DEC);
return true;
void gps_enable(void)
if(debug)
Serial.println(F("\nEnabling GPS ..."));
digitalWrite(pin_gps,LOW); //Enable GPS mode
digitalWrite(pin_gsm,HIGH); //Disable GSM mode
delay(2000);
void gps_stop(void)
if(debug)
Serial.println(F("\nDisabling GPS ..."));
digitalWrite(3,HIGH); //Enable the GSM mode
digitalWrite(4,LOW); //Disable the GPS mode
delay(2000);
void gsm_enable(void)
if(debug)
Serial.println(F("\nEnabling GSM ..."));
digitalWrite(pin_gsm,LOW); //Enable GSM mode
digitalWrite(pin_gps,HIGH); //Disable GPS mode
delay(2000);
boolean powerUpSim908(void)
if(debug)
Serial.println(F("Powering up SIM908"));
boolean turnedON = false;
//uint8_t answer=0;
int cont;
for (cont=0; cont<3; cont++)
digitalWrite(pin_power,HIGH);
delay(1500);
digitalWrite(pin_power,LOW);
Serial.println(F("Checking if the module is up"));
if(sendATcommand("AT", "OK", 5000))
cont = 4; // Leave the loop
turnedON = true;
else
turnedON = false;
if(debug)
Serial.println(F("\nTrying agin to turn on SIM908"));
if(turnedON)
if(debug)
Serial.println(F("Module is tunrned up\n"));
else
if(debug)
Serial.println(F("Module is NOT tunrned ON\n"));
return turnedON;
void gps_on()
uint8_t answer=0;
uint8_t gpsrst=0;
Serial.println(F("Turn on GPS Power\n"));
answer = sendATcommand("AT+CGPSPWR=1","OK",2000);
if (answer == 0)
while(answer == 0){
Serial.println(F("GPS Power ON\n"));
Serial.println(F("Set GPS ON autonomy mode...\n"));
gpsrst = sendATcommand("AT+CGPSRST=0","OK",2000);
if (gpsrst == 0)
while(answer == 0){
Serial.println(F("GPS set Mode : Autonomy mode\n"));
void gpsTracking(uint8_t istrack)
while(istrack == 1)
get_GPS();
send_HTTP();
delay(5000);
it just show NOT READY TO GO, Check the battery level. i use 7.5 V 2A to power it
please help me
2025-02-19 10:15:59
For sure, but I didn't figure out which sample code you are using?
Or you could visit the wiki for the newest library. https://www.dfrobot.com/wiki/index.php?t ... KU:TEL0051)#Tutorial
userHeadPic Leff
2016-07-30 09:31:03 i use GPS/GPRS/GSM Module V3.0 (SKU:TEL0051) + arduino uno
can you help me?
userHeadPic NataliaSiska
2016-07-29 21:33:49 Sorry can you give me a product link? I always play TEL0051 but few trying on others. userHeadPic Leff
