Forum >Visual Basic.net and Visual C#
LattePandaGeneral
userHead cinemapete 2016-08-09 16:28:11 4531 Views3 Replies
I am considering the Lattepanda for development work with Windows 10 and external devices via USB. The LattePanda has Windows 10 built in, so it would be an obvious question to ask can the LattePanda's embedded Atmel processor be programmed using Visual Basic.net ? If so, can anyone explain the process of setting that up to work with the LattePanda, i.e. setting up a VB..net project for this purpise, what .Net Libraries need to be included, etc, and also provide a few sample projects that use VB.Net or C#.net ? Thanks.
2016-08-15 19:11:11 There is a sample, maybe you can make a reference:
http://www.instructables.com/id/Using-V ... duino-Uno/
userHeadPic Wendy.Hu
2016-08-10 04:31:38 Thanks Wendy for your reply, unless I missed it I have not been able to locate anything specific about VB.net and the Lattepanda on either the www.lattepanda.com site or theArduino.cc sites that you provided... can you provide more specific info? Thanks again. userHeadPic cinemapete
2016-08-10 02:15:25 Hi
you can use atmel pin by COM port and we already upload standard firmata on it.Please find out more from Arduino.cc and www.lattepanda.com
