Forum >[LattePanda 2G/32GB] && GPS/GPRS/GSM module
Hi Guys,
I'm looking for a GPS/GPRS/GSM module compatible with the Arduino Leonardo embedded on this board without success.
Please can you help me?
Pasquale
Pasquale
2016-09-22 00:17:41 Hi Wendy.Hu!
It works in USB debug mode using AT commands!
Connection Scheme:
SIM808
Vin: **2V (external power)
GND
Lattepanda
LattePanda's GND connected with the SIM808's GND
D10,D11 (tx and rx pins) connected on rx and tx pins of the SIM808.
In the Arduino sketch I defined a SerialSoftware object on these pins: all the AT operations work like a charm
Thanks for your support!
Pasquale
Castellano Pasquale
Connection Scheme:
SIM808
GND
Lattepanda
Pasquale
2016-09-14 00:09:26 Hi Wendy.Hu!
Thanks for your answers!
For space reasons,I would like to use only the Arduino Leonardo embedded on the LattePanda to connect the SIM808. If I use another Arduino Board I need to use an USB port (it is too precious and I wouldn't use it
). For work I need to use all the USB ports without any HUB usb.
Could I connect the SIM808 on the Arduino Leonardo using the Rx (pin 2) and Tx (pin 4) and the power?
Thanks!
Pasquale
Castellano Pasquale
Thanks!
Pasquale
2016-09-13 23:05:15 Yes, SIM808 can be used in LattePanda , but you need another controller to connect to the SIM808, like uno, then connect the uno to LattePanda.
Wendy.Hu
2016-09-08 06:39:51 Hi Wendy.Hu,
thanks for your answer!
On the store, there aren't GPS/GPRS/GSM shield with the pinout compatible with the Arduino Leonardo embedded on the LattePanda board
Today I purchased the GPS/GPRS/GSM shield SIM808. It could work on the Lattepanda board?
Thanks!
Pasquale
Castellano Pasquale
Thanks!
Pasquale
