Forum >[LattePanda 2G/32GB] Add others ports USB/COM
LattePandaGeneral
userHead Castellano Pasquale 2016-09-09 02:20:25 3348 Views3 Replies
Hi Guys :D,
Is it possible to add others ports on this board, such as USB or COM port?
Pasquale
2016-10-20 19:04:58 There is no more com port pin extract from the board. You can add USB HUB is you need more USB port userHeadPic Wendy.Hu
2016-10-08 07:57:51 Hi!
On "device manager" there is a mysterious COM port named COM1. What can i do to use this port? Where are its pins on the board?
Thanks!
Pasquale
userHeadPic Castellano Pasquale
2016-09-13 23:12:14 Sorry, it seems that we dont have excess solder joints to solder other ports. userHeadPic Wendy.Hu
