Forum >Bluno M3 Micro Controller
Bluno General Arduino
userHead tomch 2016-09-15 19:40:26 3636 Views3 Replies
Good Day,
I see this warning on the bluno M3 wiki
"The STM32 is a 3.3V processor. Do NOT use any 5V sensor/module with it in case of burning it!"
Is it OK to power the Bluno M3 using a 5v wire from a motor controller to the 5v pin on the bluno m3 ?
Tom
2016-09-27 00:35:53 :) userHeadPic Wendy.Hu
2016-09-24 17:44:16 Good to hear, thanks Wendy userHeadPic tomch
2016-09-19 22:43:18 Hi Tom,
Yes, you can. When you connect 5V to the 5V pin on the Bluno M3, the IO port still output 3.3V.
