DfPlayer recommended speaker impedance?
userHead anonymous 2016-10-05 05:20:34 6678 Views2 Replies
I noticed on the description of the DfPlayer Mini mp3 player that it should have < 3W speakers, but there is no mention of the speaker impedance. What speaker impedance should be used? Will 4 ohm speakers work good?
2016-10-08 16:15:36 Hi Sir,
Generally, only if the power is less than 3W, it will work well. No clear requirement for impedance, eg: 8ohm, 0.5W will also work well.
userHeadPic Wendy.Hu
2016-10-07 19:45:50 I'm running with a 3W 4ohm speaker. Works well. It gets "loud enough" for a 3W speaker... userHeadPic steveplatt
