Forum >BLE beacon upload sketch problems
Bluno General Arduino
userHead kevindekemele 2016-10-10 04:49:38 4999 Views5 Replies
I've bought a BLE beacon from you guys and at first it worked great make_clickable_callback(MAGIC_URL_FULL, '(', 'https://www.dfrobot.com/wiki/index.php/DF-Beacon_EVB_SKU:_TEL0086', '', ' class="postlink"'))
I could connect my phone, communicate with the virtual terminal of Arduino IDE and upload a sketch.
Now the first two features still work, but uploading a sketch has become impossible. While my PC still recognized the arduino, and I can still communicate using the 'AT' command with a terminal
The errors I receive are always the same:
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x94
the number after resp=0x94 sometimes differs, but you get the pint.
I tried many solutions similar problems on these forums did not solve.
I updated the firmware to 1.97 (1.94 was on it) as described bymake_clickable_callback(MAGIC_URL_FULL, ' ', 'https://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267#Update_BLE_Firmware_on_Bluno.EF.BC.88AT.2BVERSION_to_check_the_version.EF.BC.89', '', ' class="postlink"')
and installed bootloader 2.0:make_clickable_callback(MAGIC_URL_LOCAL, ' ', 'https://www.dfrobot.com/forum', 'viewtopic.php?f=18&t=1733', ' class="postlink-local"')
Does anybody know what the problem could be?
It worked just fine yesterday!
2016-10-24 23:30:59 Hi kevindekemele,
In theory, you can program the Bluno beetle to send AT commands to the BLE micro, but there seems to be a little difficult, we dont have this aspect of tutorial. Here is a post link, maybe you can make a refernence:make_clickable_callback(MAGIC_URL_LOCAL, ' ', 'https://www.dfrobot.com/forum', 'viewtopic.php?f=2&t=1368#p7188', ' class="postlink-local"')
userHeadPic Wendy.Hu
2016-10-21 01:50:34 Hello Wendy,
When it worked, I was using several Arduinos, and may have had the impression that the BLE micro was printing to the serial monitor, but probably it was an arduino then!
Anyway, I also have a Bluno beetle, which is 100% programmable. I have linked bluno beetle and BLE micro. Can I program the Bluno beetle to send AT commands to the BLE micro? In this way the BLE micro would be programmable to a degree.
userHeadPic kevindekemele
2016-10-21 00:32:47 I know which product you are talking about and I also look at the schematic before. The outputs on the BLE micro are not digital ports, they are just the pins of the BLE chip-CC2540, can be used for BLE development.
Yes, it does have a USB, which can be connected to the PC, you can use it to set the BLE to AT mode,etc. And I did a test to upload the code to the board, there was a error when uploading. So I'm really curious about how you did it.
Actually it can not upload the program indeed. Of course, you can use it for wireless programming.
2016-10-20 22:11:14 It has a micro USB, and is recognized as an Arduino uno by my PC.
I just uploaded a sketch before, and it worked (just printing stuff to serial monitor..).
By the way, if you look at the link, the BLE micro has a lot of digital outputs, how can it not be programmable?
2016-10-15 01:38:05 Hi Sir,
A little strange, the blemcro is just a ble board, no mcu, so cant upload the code. How did you upload the code?
