Forum >Wireless GamePad V2 PROBLEMS
Hi! I was doing some test with the gamepad uploading some sketch. After several tests the GamePad don't want to connect. The computer does not recognize the GamePad. How I fix that???
2016-10-15 00:43:35 Hi Sir,
Can you give me more detailed about your diagram? Did you use a USB to ICSP to connect to pc? There is not a serial port, right? or cant be recognized by pc?
Wendy.Hu
