Forum >Running a LattePanda with an ePaper-display
LattePandaGeneral
userHead Account cancelled 2016-10-29 02:16:19 3501 Views2 Replies
Hello dfrobot,
is it possible to run this display with the LattePanda?
make_clickable_callback(MAGIC_URL_FULL, '
', 'http://www.pervasivedisplays.com/products/740', '', ' class="postlink"')
they also offer a 10 Inch Version. Could this be made possible too?
Here a link to the 10 Inch Version
', 'http://www.pervasivedisplays.com/products/102', '', ' class="postlink"')
Also, I wanted to power my LattePanda with a power bank. This is working, right? Meaning I just need a 5V powerbank, plug it in and it will work. Could the Panda also be powered via USB 3.0, or does it need to be via mico-usb-slot?
Thanks a lot!
2017-08-14 09:20:46 A power bank may not work for reasons I outline on other threads. 2.1 amp output on a power bank is marginal at best for doing anything other than powering up the board. It may not be enough to drive a display or run energy intensive programs or video. userHeadPic raymostrom
2016-10-31 22:22:28 They are e-ink displays .so no matter drivers or the connectors are not supported with the LattePanda.
And yes you can use a 5v power bank for it. both Micro USB port and 2-pin header can work for it.Just make clear the positive and negative
userHeadPic Wendy.Hu
