Forum >latte panda does not fit into acrylic case with cooling fan
LattePandaGeneral
userHead amor.odium 2016-11-17 17:19:16 5509 Views3 Replies
I just got this, and with the cooling fan attached (which is never, ever coming off with the thermal tape they supply) it will not fit into the acrylic case that came with the kit and let the fan spin. even with the 4 retainer pieces removed and the board loose inside, it is pressed against the grate and does not spin. has anyone else seen this?
2016-11-18 22:14:43 Hi Sir,
I know your problem, did you try to push out the board as shown in the pictures to install the fan? As for your specific troubles I am also not clear enough. If you still have some problems about the installing, you can send email to this address:make_clickable_callback(MAGIC_URL_EMAIL, ' ',make_clickable_callback(MAGIC_URL_EMAIL, ' ', ''[email protected]', '', '')', '', '') for more detailed query. Hope it will help you.
('0', 'QQ图片20161118140748.png')
userHeadPic Wendy.Hu
2016-11-18 05:15:32 Wendy, I do not have pictures I am at work fright now. but the issue is that with the cooling fan installed make_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.dfrobot.com/index.php?route=product/product&search=lattepanda&description=true&product_id=1520', '', ' class="postlink"')
this case from the starter kitmake_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.dfrobot.com/index.php?route=product/product&search=lattepanda&description=true&product_id=1551', '', ' class="postlink"')
it is pressed against the fan. Am I supposed to break that grid out of the panda's case?
userHeadPic amor.odium
2016-11-17 23:25:12 Hi Sir,
Sorry, I am a little not very clear what are you talking about. Do you want to say that the box is not suitable? Any pictures?
