Forum >Using Bluno beetle for trilateration
Bluno General Arduino
userHead gupo93 2016-12-04 13:54:42 2925 Views3 Replies
Hello Everybody!
I'm doing a project for my university in which I have to use 4 bluno beetles.
3 of them are set as iBeacons and they are fixed on a position, the fourth is attached to a bracelet (so it is mobile) and it gets the RSSI from the other three, in order to perform the trilateration ( this operation is
obviously performed by a server to which the mobile bluno sends the values).
In this way I will get the position of the mobile beetle in the space at each instant.
The problem is to continue to make the switch and constantly get the three RSSI.
Here's the code I've tried (the sketch of IBeacons is empty), but it does not work (it is inspired by others sketch of previous topics of this forum):
typedef enum {START, WAIT_AT, WAIT_BIND, WAIT_RSSI, WAIT_EXIT, NORM_MODE,CLEAN_STATE} rssi_state_type;
rssi_state_type state = START;
char chr;
String buffer="", rssi="", data="";
String MACS[3] = {"0xC4BE84E397E6","0x9059AF16A3C2","0x9059AF169CF3"};
String current_mac ;
int index =0;
bool reading = false;
int count=0;
Serial.begin(115200); //Initiate the Serial comm
while(!Serial){
state = START;
if (state == START) {
start();
} else if (state == WAIT_AT) {
wait_at();
} else if (state == WAIT_BIND){
wait_bind();
} else if (state == WAIT_RSSI) {
wait_rssi();
} else if (state == WAIT_EXIT) {
wait_exit();
} else if (state == NORM_MODE) {
norm_mode();
void start() {
count=0;
delay(1000);
Serial.flush();
clean();
//AT COMMANDS
Serial.print("+");
Serial.print("+");
Serial.print("+");
data = "";
state = WAIT_AT;
void wait_at() {
while (Serial.available() > 0) {
chr = Serial.read();
//buffer+=chr;
if (chr == 'E') {
reading = true;
buffer = "";
if (reading) {
buffer += chr;
} else {
data += chr;
if ( buffer == "Enter AT Mode\r\n") {
data="";
current_mac = MACS[index];
Serial.println("AT+BIND="+current_mac);
buffer="";
reading = false;
state = WAIT_BIND;
void wait_bind(){
buffer+=chr;
if(buffer == "OK\r\n")
buffer="";
Serial.println("AT+RSSI=?");
state= WAIT_RSSI;
void wait_rssi() {
if (chr == '-') {
reading = true;
buffer = "";
if (reading) {
buffer += chr;
if (buffer.length() == 4) {
rssi = buffer;
Serial.println("AT+RESTART");
reading = false;
state = WAIT_EXIT;
if (rssi == "-000") {
//TO BE PREPARED
void wait_exit() {
buffer = "";
delay(3000);
state = NORM_MODE;
void norm_mode() {
Serial.println("\r\n<<<");
Serial.println("RSSI letto da " + current_mac + "E' : " + rssi);
Serial.println(">>>\r\n");
Serial.flush();
if(index < 2)
index++;
else
index=0;
state=START;
//cleans the transmission buffer
void clean ()
while (count < 64)
while(Serial.available() > 0)
Serial.read();
count++;
delay(10);
state=START;
In particular, i cant't see the RSSI values on the Serial monitor, so I can't do Debugging operations.
I would be grateful if someone could help me.
while I wait for answers, many thanks to all of you.
2016-12-07 00:17:55 Enn, perhaps it is not a good idea to use bluno beetle to act as a RSSi scanner. On bluno, you can only get the RSSI after two bluno is connected to each other. It will take a really long time to connect and get the RSSI. How about try to use other board like Intel Edison as central? They can scan the iBeacon without connect to them. userHeadPic Angelo.Qiao
2016-12-06 01:30:32 Thank you so much for your availability.
Now I understand how to get correctly the RSSI, but my problem is to switch beetween the three Ibeacons. My goal is bind one of the iBeacons in every cycle of the loop, in order to be able to obtain the necessary values for trilateration every three cycle. I Tried with my code, but it does not work (i tried also with the restart command instead of the exit command).
Thank you so much.
userHeadPic gupo93
2016-12-05 20:39:30 Hi, you can try this demo to get the RSSI.
It use software serial to show the debug message.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
bool isATCommand=false;
int requestRssi()
int rssi;
char buffer[10]={0};
if (isATCommand) {
while (Serial.available()) {
Serial.read();
Serial.print("AT+RSSI=?\r\n");
if (Serial.readBytesUntil('\n', buffer, 9)) {
isATCommand=true;
rssi=atoi(buffer);
return rssi;
else{
isATCommand=false;
return 0;
bool enterATCommand()
char buffer[16];
Serial.read();
Serial.print(F("+++"));
Serial.readBytes(buffer, strlen_P(PSTR("Enter AT Mode")));
if (!strncmp_P(buffer, PSTR("Enter AT Mode"), strlen_P(PSTR("Enter AT Mode")))) {
isATCommand=true;
else{
isATCommand=false;
return isATCommand;
mySerial.begin(9600);
while (!enterATCommand()) {
Serial.println();
isATCommand=true;
requestRssi();
if (isATCommand) {
break;
delay(500);
static unsigned long requestRssiTimer=millis();
if (millis()-requestRssiTimer>500) {
mySerial.println(requestRssi());
if (!isATCommand) {
delay(500);
