Forum >Loose Tank Tracks - too many links
RoboticsGeneral
userHead Account cancelled 2017-01-04 19:22:17 4328 Views3 Replies
I just finished assembling the Devastator Tank Mobile Robot Platform (Metal DC Gear Motor) SKU:ROB0128. When I added the tracks, one side was very loose. I switched tracks and the other side was very loose. I counted the links and found one has 53 links, but the other had 54 links. If there an easy way to remove a link from the long track? Has anyone else had this problem?
2019-07-07 19:04:11 Hi, I cannot see the attachements, it says "The selected attachment does not exist anymore." userHeadPic mustafa.o.k
2017-01-04 22:04:05 Hi Sir,
Dont worry, its normal. Since we set aside part of the tracks, which is rather loose to the wheels. You can take out one or some tracks to make them tight. The detailed steps you can refer to the attachment.
Hope this will help you.
[attachment=0]QQ图片20170104140209.png[/attachment]
[attachment=1]QQ图片20170104140151.png[/attachment]
userHeadPic Wendy.Hu
