Forum >LP 4G/64Gb doesn't boot, stuck at Shell> prompt
I have done a BIOS refresh (that worked ok) and created a new Windows image x64 version for 4G/64GB as described in documentation.
When booting, with or without new image on USB no result, it keeps coming back to the Shell> prompt. See attached screen image.
How can i get this back no normal ?
Many thanks,
André
Many thanks,
André
2017-02-04 03:27:01 I have exactely the same problem and we are not alone unfortunately.
Have you got fixed this issue ?
achat
2017-01-09 23:49:09 Does the usb port working when you use the keyboard?And can you press“Esc”to get into the Bios setting page to make sure the Bios files are fine? And try other usb port if one of them not work
Wendy.Hu
