Forum >Antbo
RoboticsGeneral
Antbo
userHead eseftel 2017-01-08 17:56:26 9857 Views19 Replies
Hi. Was part of indiegogo fund and Just received Antobo and put it together, am having problems getting it to work at all.
1) have it connected via usb Cable to mac and Bluetooth to ipad app. App keeps trying to update firmware but it never completes and just restarts
2) legs do not function. Have removed and reinstalled while in leg calibration mode but they don't move, tho lights are on. Servos rotate and are installed in correct positions.
3) antbo won't respond to light, voice etc
4) search of dfrobot.com site or doesn't result in any
troubleshooting info
Thanks for any help you can provide. If unit is defective can you provide new one?
2017-01-23 01:27:27 Hi Lim,
it has supported android for the firmware uploading. Recently we also fixed this bug on Anrdoid 6.0
Blue light means the it has been ON, you need to touch the head once again to enter patrol mode. If the antbo has been in OFF mode, touch the head twice to enter calibration mode (LED is orange)
So, we can start it like this:
Touch the head for 3s to wake it up, touch the head again for walking, After 60s walking, it will be ON mode again.(Standby), turn the head 3s to turn it off.
userHeadPic Grey.CC
userHeadPic Grey.CC
2017-01-22 19:36:41 It's functioning well on Day 1 though needs some tries to get into Blue light - is it normal?
On day 2, always in calibration mode and stopped. Legs not straightened after that.
Still the same after removed batteries and reset.
Can't do firmware upgrade via Android.
Please help.
userHeadPic Lim Allan
Please help.
2017-01-21 00:09:30 Hi
Please power the antbo via the USB, then try to update firmware again. Hope this will help you.
userHeadPic Wendy.Hu
2017-01-17 07:04:47 Sure.... the process started and when the advance bar almost finish, the app in my iPhone stop working.
Alter that the antbo don't start... not a light, nothing...
It seems to me that the update process failed, but I can't re-start the process (as I wrote, the antbo is completely dead)... May be if I update the firmware using the cable I will be able to recover the antbo.
userHeadPic Quiroga-cod272 Milton
2017-01-16 18:34:06 Hi
May I know what happened during the process of updating firmware? These would be better for me to help you. :)
2017-01-14 11:31:58 I tried, but in the middle of the firmware update, something happened and the process was interrupted.
Now the antbo don't start.
Is there a way to update the firmware using the cable?
Thanks,
Thanks,
2017-01-13 19:28:01 Hi Quiroga-cod272 Milton,
We have released the new version app on the apple store, please go to there to download, then try again. When updating the firmware, please make sure not connect to usb, just batteries.
Contact me if you have any problem. :)
2017-01-13 14:39:09 Same problem here... it appears death on arrival. userHeadPic Quiroga-cod272 Milton
2017-01-09 19:09:52 Hi eseftel,
Sorry for your bad experience.
Actually, the problem does exit. We have submitted the new version of App and are waiting for Apple's audit. After the completion of the audit, the latest version will be updated automatically according to the network or idle time.
Now, before that, you can try this to solve the problem: when the firmware update reaches 100%, close the APP, open the Antbo, and then open the APP again, everything would be fine.
Let me know if you have any problem.
2017-01-08 17:56:26 Hi. Was part of indiegogo fund and Just received Antobo and put it together, am having problems getting it to work at all.
userHeadPic eseftel
