Forum >Combining channels on 2x15A dual motor driver
RoboticsGeneral
userHead Account cancelled 2017-01-10 06:07:27 1926 Views1 Replies
I need to supply a DC motor with approx 20A continuous. I want to combine the dual channels into a single channel in order to achieve this.
My board is the DFRobot 2x15A lite and is based on the BTS7960.
The analog voltage is applied to both m1_pwm and m2_pwm inputs simultaneously. What is the best way to combine the channels?
1) Run both channels in the same direction (both m1_en & m2_en high). Wire M1 & M2 + outputs together and M1 & M2 - outputs together?
2) Run the channels in opposite direction (m1_en high & m2_en low). Wire the motor using M1 + and M2 + outputs.
2017-01-12 01:29:09 Hi Sir,
In theory, what you said is feasible. But I am not sure, we havent tried it before. If you really want to do like that, you can try to do . If you succeed, thanks for your sharing.
Have a nice day. :)
userHeadPic Grey.CC
