Forum >LATTEPANDA fails to boot: no blue/no red leds
LattePandaGeneral
userHead acarrizzo1 2017-01-14 04:28:35 2551 Views1 Replies
Hello!
yesterday i have try to normally boot lattepanda using the same power that we have used month ago. When I connect the cable I see blue led just for a second and then the it is dead!...
now when I connect the cable i don't see any leds....
how i can fix this issue?
there is the possibility to flash bios via PC?
Is it possible to fix whithour RMA?
thanks in advance
2017-01-23 01:57:06 Hi it sounds like an accidental short-circuit. Do you smell any burning? It is better to make a further check,Just RMA! userHeadPic Grey.CC
