Forum >LattePande 4GB/64GB and USB Hub and RS232
LattePandaGeneral
userHead Account cancelled 2017-01-19 11:21:01 3152 Views2 Replies
Does anybody have an idea if LatterPanda supports USB hub (in other words can I connect 7 ports USB hub to LattePanda board)? May be someone has expirence with that. Also, is there any way to connect RS232 to LatterPanda?
Thank you!
2017-08-14 09:07:41 I have connected a 7 port powered USB hub to allow connecting the mouse, keyboard and a 120 Gb HD and this works well. The powered hub dfrobot power to the LP board as well. Make sure the power supply to the hub is at least 2 amp. userHeadPic raymostrom
2017-01-21 01:52:41 yes, you can link a usb hub on it , just notice the power supply.And there's a UART ttl port you can use to connect with RS232 on the board. And you can use the port by Arduino or other Language userHeadPic Wendy.Hu
