Forum >Fit0491 metal gear lead screw
RoboticsGeneral
userHead jdelcamp0 2017-02-15 18:10:54 2152 Views3 Replies
I purchased the FIT0491.
The specs describe the lead screw as M4*55. There is no mention of the thread count.
The local hardware shops have all tried to fit a standard M4 nut, but say the threads aren't correct (70). What is the correct nut for this lead screw? And do you sell them?
2017-03-06 18:54:49 Yes, you can. Please send email to our sales:make_clickable_callback(MAGIC_URL_EMAIL, ' ', '[email protected]', '', '') userHeadPic Wendy.Hu
2017-03-04 13:52:05 We have tried several standard M4 nuts and they will not go on.
(the *55 is the length of the shaft).
If you cannot find the correct nut specifications, can I return the motor?
I cannot use it if there is no matching nut.
userHeadPic jdelcamp0
2017-02-23 22:58:10 Hi
Sorry for the late reply.
I have checked the threads info, it should be M4*55, no problem. I dont know much about the local hardware shops.
Its a pity that we dont sell them, or you might can go to shops for customization?
