Forum >Lattepanda + touchscreen case
LattePandaGeneral
userHead Account cancelled 2017-02-23 11:08:14 2657 Views1 Replies
Hi, I would like to build a "panel pc" for my house: it means a lattepanda+IPS+TouchScreen inside a wall, working as a LCD panel with touchscreen interface that controls lights, sensors and so on.
Now, I would ask you some advice about the case/frame I should use with it: a 3D printed one? Or a wooden/plexiglass one? Moreover, would it have some heating issues inside the wall?
Please tell me what you would do.
thanks
Antonio
2017-02-23 23:07:32 LattePanda release two good cases using plywood /acrylic in DFstore. And you can find some incredible cases on thingiverse ,Which you can 3D-printe it, or made by you own.
And the board will get heat ,a lot of heat .The temperature of CPU will over 50 in normal use and 80 when you running a big software.So I think a cooling fan or some heat sinks are important
userHeadPic Wendy.Hu
