Forum >[LattePanda 2G/32GB] - Disable IPS Display from BIOS
Hi Guys!
When I use Remote Desktop programs without using a secondary monitor, the screen size is 1024x600
Is there any way to disable the primary screen of Lattepanda?
Thanks a lot!
Pasquale
Thanks a lot!
Pasquale
2017-03-23 03:20:30 Hi!
I've solved the problem using a Display Emulator
http://www.fit-pc.com/web/products/fit-headless/
Thanks a lot!
Pasquale
Castellano Pasquale
Thanks a lot!
Pasquale
2017-02-28 05:39:52 Hi!
Thanks for your answer!
I've tried your procedure but LP don't want to boot without a screen connected (tx led start to blink).
If I connect the HDMI screen, LP boots properly.LP enables the HDMI port when a screen is connected. I need to access to LP without a screen connected with the HDMI resolution. Is there any way to do this?
Thanks a lot!
Pasquale
Castellano Pasquale
Thanks a lot!
Pasquale
2017-02-27 23:11:14 Hi
If you don't need to use the 7" MIPI display on the board. You can disable the Force Lid Status in BIOS setting -> Chipset -> North Bridge -> IGD- LCD Control ->, then I think you can change the screen Size as you wish
Wendy.Hu
