Forum >EC Meter Calibration
Hi all, this is the first time I post in the forum.
I recently bought a EC meter from here (see Product link)
After reading the wiki, I'm able to get the probe to work but the problem comes when I try to calibrate the probe.
As the "Scheme of Calibration" section said that "I should make my solution temperature be at 25℃" to perform a calibration. I wonder that is there any workaround solution if I calibrate the probe when the solution's temperature is higher or lower than 25 ?
> Product link:make_clickable_callback(MAGIC_URL_FULL, ' ', 'https://www.dfrobot.com/product-1123.html', '', ' class="postlink"')
> Wiki link:make_clickable_callback(MAGIC_URL_FULL, ' ', 'https://www.dfrobot.com/wiki/index.php/Analog_EC_Meter_SKU:DFR0300', '', ' class="postlink"')
Thank you.
Thank you.
2017-03-02 01:23:45 Hi,
The temperature is just a relative parameter, the environment temperature will be ok. And here is a note below "Scheme of Calibration" , the method of calibration would be more easier.
Wendy.Hu
