Forum >Disabled setting in bios
LattePandaGeneral
userHead anonymous 2017-03-10 16:17:03 3263 Views5 Replies
I think I may have accidentally disabled the igp, I don't get anything out of the HDMI port now. I tried using the bios tool with a USB. I used version 1.0. I left it connected for 10 minutes rebooted it and nothing.
On inspection I don't see the USB device being read. The indicator isn't flashing and the keyboard doesn't function.
What can I do?
2017-03-14 06:29:53 Hi!
Real problem is that LP doesn't have a CLRTC jumper to reset the BIOS settings......
It would be nice to have this possibility, without needing to buy a programmer for the BIOS.
Pasquale
userHeadPic Castellano Pasquale
2017-03-14 00:48:09 :D:D Great! userHeadPic Wendy.Hu
2017-03-13 03:44:41 Hi,
This can now be closed , I purchased a CH341A USB tool and clip to flash the bios.
Thanks !
userHeadPic anonymous
2017-03-10 16:46:58 Thinking really hard. I know exactly what I have done.
I enabled "dual channel support" now it doesn't boot. Is here anything you can do to help? Why is it even an option?
2017-03-10 16:19:24 I imagine I've done this , his is from another user
"Hi!
Thanks for your answer!
I've tried your procedure but LP don't want to boot without a screen connected (tx led start to blink).
If I connect the HDMI screen, LP boots properly.LP enables the HDMI port when a screen is connected. I need to access to LP without a screen connected with the HDMI resolution. Is there any way to do this?
Thanks a lot!
Pasquale"
What can I do?
