Forum >TCS3200 GBB Color Sensor how fast does it react ?
RoboticsGeneral
userHead Account cancelled 2017-03-14 04:16:17 1717 Views1 Replies
I want to use the TCS3200 GBB Color Sensor for the Arduino. The sensor must take measurements of passing by object, which are pretty fast, something around 1 m/s.
Can the mentioned sensor keep up with the speed requierments from the passing by objects? I only need one value, as example the red value of the passing by object.
2017-03-17 01:02:16 Hi
In theory, the effective detection range is 10cm, so I am afraid that its hard to detect the moving objects, except the moving objects is very close to the sensor I guess.
userHeadPic Wendy.Hu
