Can't get APC220 to work
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
I'm trying to configure it through Arduino, which should work according to everyone, but isn't.
Thanks in advance.
Output is "here we gooo:" "done!". Everything works perfectly, including the LED, but no data is coming from the APC.#include <SoftwareSerial.h>
//rafaboi
const int rxPin = 0;
const int txPin = 1;
const int setPin = 2;
const int enPin = 3;
const int fiveV = 4;
SoftwareSerial thing(rxPin, txPin);
// put your setup code here, to run once:
Serial.begin(9600);
thing.begin(9600);
pinMode(setPin, OUTPUT);
digitalWrite(setPin, HIGH);
pinMode(fiveV, OUTPUT);
digitalWrite(fiveV, HIGH);
pinMode(enPin, OUTPUT);
digitalWrite(enPin, HIGH);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(1000);
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(setPin, LOW);
thing.listen();
thing.println("RD");
delay(10);
Serial.println("");
Serial.println("here we gooo:");
/*while (thing.available()) {
Serial.print(thing.read());
Serial.println("done!");
// put your main code here, to run repeatedly:
if (thing.available() > 0) {
Thanks in advance.
