Forum >WIFIbee MT7681 PB
WIFIbee MT7681 PB
It's not possible to connect the module to a network following these instructions : Configure the wireless network parameters via AT command
I also try to create a wireless network called ouki as the example with the same password... but no result.
I don't understand
Thanks for your help!
I don't understand
2017-04-27 21:53:49 Hi
Sorry for the late reply.
I got a reply from our R&D team that probably its the problem with the software, we will release the new version in the middle of May. Thanks for your patience.
Wendy.Hu
Wendy.Hu
2017-04-24 23:05:53 Hi,
No new information about a firmware update ? I can be a beta tester if needed
anonymous
anonymous
2017-04-15 02:41:42 I will do some test to confirm the problem, it seems there are some problems indeed. I have give a feedback to our R&D team, I will let you know the further result.
Wendy.Hu
Wendy.Hu
2017-04-12 09:59:26 Hi,
Thank you for your answer.
However, I tried with my mobilephone too which was very close to the module (few centimeters).
When the module is in AP mode, i can see the network.
In STM mode, i have SM=2, Sub=0, so the module tries to connect to the network according to the machine state in the datasheet but it returns to initialization mode and switches to smart link. I tried with different authentifications too without success.
A scan AT command should be interesting to debug.
anonymous
anonymous
2017-04-10 23:36:07 Hi
Sorry for your bad experience. Did you try to stay close with your router? And same problem? Actually I got some same feedback from other people, it seems there are some problems indeed. I did a test and if I stay close with my router, it will be connected.
In addition, I have give a feedback to our software team, any update I will let you know.
Wendy.Hu
Wendy.Hu
2017-04-10 01:08:45 Hi,
With SmartLink, same problem...
waiting for smartlink...
SM=1, Sub=0
SM=0, Sub=0
SM=1, Sub=0
anonymous
SM=1, Sub=0
SM=0, Sub=0
SM=1, Sub=0
SM=1, Sub=0
SM=0, Sub=0
SM=1, Sub=0
anonymous
SM=1, Sub=0
SM=0, Sub=0
SM=1, Sub=0
2017-04-09 14:28:57 Hi,
I don't understand
anonymous
I don't understand
